Help needed with PC3x - doesn't keep working more than 40 minutes
Just shooting from the hip here but I'd guess that the power supply is overheating.
Do you have it in a dusty environment?
Do you own a cat or a dog?
I'd suggest opening it up and vacuuming the crud and dust out of the chassis and power supply and see if that fixes it.
- Maybe... Do you know what would be a decent operation temperature? I will try to find a way to measure it
No. Only in my apartment, never get it out.
None. The only animal who lives here and touches this keyboard is me myself.
I already did that and got no success. But I will consider your tip on the temperature.
Thanks man, really appreciate your support.
Best regards.
