HELP with WK-3800 ... loss of rythm and mod wheel ????
Mysteriously I have no sound from any Rhythm ... the screen shows it playing, but theres no sound and the lower keys are dead.
additionally, the Mod wheel now does nothing. Affects none of the tools, even organs
My grandson (5) has a fascination with pressing buttons ... could he have somehow disabled those functions, or is this unit ready for the junk yard?
Regards, and thanking you in advance for any help you can give.
Fred
Try resetting it just in case your Gkid found a button combi that disabled the features.
  1. Press the Transpose/Function button
  2. Cursor down 3 times to Init Mix, cursor right to Init Sys
  3. Press Yes twice and do not press any keys when it says “Please Wait.”
  4. Press Exit once and it’s ready to go!
So trust Casio to have an elaborate reset procedure
Thank you ! That did the trick -- although I lost all of my presets. That's okay. Thank you for answering!
