STILL trying to fix my DGX-500...
Anyway, I bought a new contact board. The problem is that the boards attach to each other with these cloth bands with a bunch of tiny wires running through them.
The end of one band has a row of short, tiny wires sticking out, and the other band has a plastic thing with a row of tiny holes.
Whenever I try to connect them a couple of the wires miss the holes, and then the connected notes don't play.
Is there some kind of special tool or trick that will make this easier?
