Ketron SD90 - unwanted sound occurs always C3 is played
Hello all,
Lately I bought a SD90 Pro live module 2nd hand with still valid gurantee.
While I am playing around with a midi keyboard or accordion attached I realized, that on the key of C3 (and only there) I get a additional sound after approximatly 1 second after the key press. The sound is a synthetic string sound I would say and sounds a triad higher then the played C3.
This occurs while the 2nd voice is off. And also only on this specific note - nowhere else.
What might be wrong there? Anyone experienced similare phenomenon’s?
Can I fix it somehow or is this a bug with the hardware module?
Thanks for your advice!
Cheers
Stefan
Back up the settings, do a factory reset and if it still occurs after that contact Ketron support.
Hi Happy
I can not find the factory reset procedure in the users manual.
What trick is it to perform it on thd SD90?
Any more tipps for a newbie?
Thanks for your help!
Cheers
Stefan
Thanks Dave for your reply.
Does this soft reset delete additional style files that where imported?
Thanks for this last worry I have.
Cheers
Stefan
