- Joined
- Jun 25, 2010
- Messages
- 1,679
- Reaction score
- 590
True, lots of the Krome synth/piano/acoustic sounds, and the MODX FM, etc. are things you can do on your PC... but sonically, almost anything non-analog can be done better on a PC, and as you said at the top, your purpose here is (at least in part) to have a good selection of these sounds available to you when you don't want to be tethered to a PC, so maybe that doesn't really have to be much of a concern.I am looking at an external keyboard for casual playing and jamming outside of my daw.
There are many synths on my computer (including Korg) but it's not spontaneous and I don't have many hifi instruments/acoustic sounds.
I was looking at Krome and realized it has more of synth sounds (that I can already do).
It does have nice pianos and some acoustic sounds but much alike what I may already have on my PC.
Modx did come close but the samples are a bit older and the FM I can do on my PC.
MODX sample set is pretty new. Of its 5.67 GB of sample data, about less than a gigabyte is "old" (Motif XF and earlier), almost 5 GB was new to the Montage in 2016. All but about 200 mb of the Krome EX are the same as the 2012 model. The PA700 was from 2017, though it's a smaller sound set than the MODX, and much of it is still "legacy" from the prior model. But neither newness or size is everything, and if you feel it doesn't sound as "beefy," that may be all you need to know.Modx did come to mind but the samples may be a bit older (?) and not as beefy as PA. The FM I can already do. I hear the sequencer is not as convenient as PA.
Roland FA, I checked the XV-5080 (should be similar and a bit older too) and not sure if it's the same sound palette but the Korg might have an edge?
MODX sequencer is not as capable as PA700 or Krome. But you have a DAW, which beats them all. You're not likely to be creating sequences in a "casual playing and jamming outside of my daw" environment, so maybe that doesn't need to be a concern.
Roland FA acoustic instrument sounds are mostly from the XV-5080 which, yes, is quite old, or from the almost as old SRX expansions... but its Virtual Analog and handful of SuperNATURAL acoustic sounds are newer tech.
Arrangers often have automatic articulations that vary with how you play, which I believe is some of what Korg's "DNC" does. Though if this kind of expressivity on natural sounds is what appeals to you, I think Yamaha's arrangers tend to do a better job. But it's subjective, and also depends on which sounds you're comparing.The PA700 seems to have those really good natural sounds that would complement my existing setup.
One other thing you might want to consider, if it's for casual playing and jamming, but also you care about piano, is that 61 keys can feel restrictive for piano playing (and for splits, if you'd be using them). So you might also consider what's available in a 7x.
