Looking for a replacement for a TOA KD-1
EdK
Hello all,
I've been using a TOA KD-1 portable mixer/amp for many years. TOA has discontinued this amp and parts are no longer available. I've been keeping it going for the past several years by canablizing other TOA KD-1's I had to use for spare parts but it time to upgrade.
I'm looking for a similar mixer/amp and the only ones I can find are made by NADY. Models RPA-2, RPA-4 and RPA-6 (2, 4 and 6 channels).
Does anyone use any of these NADY amps? Are you pleased with them? Is their sound comparable to the TOA? A nice feature of the NADY's is that they are made with wheels and a carry handle which the TOA's never had.
Or does anyone know of another manufacturer that makes something similar? I know Roland makes keyboard amps but I don't care for the way they sound.
My preference is 4 or 6 channels with XLR and 1/4 inch ine inputs on each channel but would settle for 1 XLR/line input and the remaining 3 or 5 as line inputs. Also, it must be one piece.
Thanks in advance for your assistance.
EdK
Hey Ed,
The QSC K series are very popular with a lot of keyboard players here.
Personally I use a separate line mixer before running into a JBL EON.
Cheers!
EdK
Hey CowboyNQ,
I appreciate your reply but I don't think you understand what I'm looking for. My TOA KD-1 is a combination powered mixer with 4 channels and speaker in one unit. Basically a small self contained portable PA system. Similar to a Roland Cube but larger with more channels and a 10" full-range speaker.
Ed
G'day Ed,
You're right, I don't know exactly what you're looking for, however I do know exactly what you have due to the magic of the internet. :)
Forgive me for suggesting some popular alternatives which, by all reports, work very well indeed.
Good luck in your search.
Regards,
Paul
