Low cost solution to mix audio from tablet and Korg PA300 and output to headphones
Hello,
I am looking for a low cost solution to be able to hear audio output from a tablet device + the sound from a Korg PA300(that has no line-in) to headphones.
Would a small mixer like this -- Behringer XENYX 502 mixing console do the job or is there a more cost effective solution? (I'm just a hobbyist wanting to learn
songs whilst using songbook pro + spotify).
Any suggestions would be highly appreciated,
Thank you for your time.
I use a rolls MX22, it does the job and is very inexpensive. built like a tank... sized a little bigger than a cigarette pack...
mx22A for sale
MX22S for sale
The MX's have headphone outs so that you can plug your headphones directly into the mixer headphone output.
MX22A has a 1/4" input and 1/4" headphone out, MX22S has an 1/8" input and an 1/8" headphone out. You'll need to decide which one (1/4" or 1/8") works best for your scenario. breakout cables (1/4" to 1/8"; 1/4" to RCA, 1/8" to RCA, etc.) are in abundance and very inexpensive (in the event you need a conversion).
Hello, thank you very much for the suggestions. The mx22A would have been perfect, but unfortunately it is not available for purchase where I live (Ukraine). However, you have given me an idea of what to look for and if I'm lucky could come across something similar. Thanks again for your time.
The Behringer will work great.
I use a similar model for the same purpose as you want.
Hello, thank you very much for the confirmation. The Behringer is available so I'll go for it. thanks for your help.
