MicroStation question -- Program vs Combination mode
When I use patches in combination mode, they always sound much thinner than when I use them in program mode. My guess is that in program mode, the MicroStation adds effects that aren't present in combination mode.
Is there a way to use the use patches in combination mode that sound like they do in program mode?
Thanks!
Bucharest
Hello.
Use the same IFX,master Fx and same IFX routing or use copy from program in combi mode using the editor: (combi,utility,copy from program,with FX.). I will help you next week when I'll be back home from my tour.
