Hello,
I am about to take the plunge and invest in my first midi controller keyboard for working in Ableton Live, it won't be used for live performance or gigging. One of my absolute pet hates is a noisy key action, I presume it's more an issue with cheaper and unweighted plasticy keys but the "thunk" of a key "bottoming out" and the "thunk" as it returns is like nails down a chalkboard to me. So do you have any suggestions on keyboard controllers that would be suitable for sequencing that as closely fit the following parameters as possible, I can then narrow down to ones to try in person.
1) Budget up to £1500 max
2) Silent key mechanism (or as near as possible)
3) Semi weighted keyboard preferred (I am not trained on a piano so find weighted keys too heavy and tiring, however I am not above learning to use a weighted keyboard should the benefits outweigh the drawbacks)
4) Solid construction (I want something that will last years and is a quality build)
5) Controlling Ableton from the keyboard is not a necessity above maybe tweaking a few current instrument parameters and the normal pitch bend and modulation.
6) Anything 49 keys and above.
7) As I will be doing all my work through Ableton, I don't need fancy arranger functions built into the keyboard.
8) Velocity sensitive.
9) After-touch would be nice.
Thanks for your help.
