Need Help Finding Replacement Keys and Hammers for Roland HP1700 Digital Piano
* New or Used
* If you have a broken hp1700 I will buy the keys and Hammers from you.
ALSO
DOES ANYONE KNOW WHAT OTHER MODEL ROLAND DIGITAL PIANOS HAVE OR USE THE SAME KEYS AND HAMMERS AS THE ROLAND HP1700 ?
Thank You
The Roland HP-900 is nearly identical with the HP-1700. The major difference is the number of keys. The HP-900 has only 76 Keys.
