Not able to save file in PSR I455
Hello
I was trying to save few songs(MP3 format) file in my Yamaha PSRI455 keyborad. But I am not able to select any file from the menu. Getting 'No Data' message. Below is the step which i have done.
1. Connected USB drive in To Device Port
2. Pressed on File control button.
3.Select Save USR option and clicked on Execute button, then am getting No DATA Message on the screen.
Please Help me to Save my file. Its VV Urgent.
The PSR-i455 does not save/load/play audio files of any kind: such as MP3/WAV/AIFF/etc. It will only save/load/play MIDI files: such as Type 0 and Type 1 Standard MIDI File (SMF) songs, Yamaha proprietary (USR) song files, and Yamaha proprietary Auto-accompaniment Style files, which are a special type of MIDI file.
See the Table in Item 4 at the top of the right hand column of Page 52 of the manual for the various USB File Control options available to you.
BUT . . . You also appear to be confused about the LOAD and SAVE operations, as well. You SAVE files from the keyboard's internal memory to the USB Flash Drive and LOAD files from the USB Flash Drive into the keyboard's internal memory.
KaveBB
