- Joined
- May 23, 2013
- Messages
- 10
- Reaction score
- 2
As you know our keyboards are USB Midi Compliant, that means you can connect them to Midi devices in some case directly tuo USB, otherwise using, for example, the Kenton Midi USB Host http://www.kentonuk..../usb-host.shtml
Those Midi app let you to controle via USB OTG, Opus#1 1843 french two manuals church organ based on high-quality recordings http://www.refined-apps.com/opus-1/ be careful the app works only 4 1/2 octaves as the real organ and Pitea a 1989 german three manual church organ always based on high-quality recordings http://www.refined-apps.com/pitea/ again be careful the app works only 5 octaves.
I'have those two apps, and I'm very satisfied, I used them even with my old Midi keyboard connected with a Roland USB/Midi compliant and even non Midi compliant, I suggest the first one. In any case read carefully the Refined Apps suggestions.
You can also use two keyboards controlling upper an lower manual with a Midi merger like the Kenton one http://www.kentonuk....m-merge4.shtml.
For IPad & Iphone go to visit http://polaron.de/Napo/index.html
I hope to have been enough clear!
