Hi,
I have a Ketron X1 and when I save new midi files to the keyboard disk it change the order number of the previous existing files, because it save new files between the older files by alphabetic order. So it provoques I have to change the sequance number of a lot of files in my songs reports.
Do you know how can I do to avoid that problem and get that new files are added at the end of the existing files in disk? That means no changing numbers. Maybe there is any configuration parameter I can change before save new midi files.
Thanks a lot for you help.
Best regards,
Nazari Meca
Best regards,
Nazari Meca
