Problem with sustain input
bhl
Hello!
I would like to ask if somebody here has some sustain solution to a keyboard with the input that was damaged by my little daughter . The rest is working fine .I do not know if there is something like a module with sustain input to connect, or perhaps configure a expression pedal to work like a sustain pedal. Any suggestion will be very appreciated.
The support told that the input has no possibility to be fixed. Only a new mainboard with new inputs.
My instrument is a Kurzweil SP2.
Thanks;
Are you certain it is the input that's fried and not the pedal that's defective? Have you tried it with more than one pedal?
Considering the sustain pedal input is a simple switch input it's pretty hard to actually blow one out. Even a dead short is a normal operating condition for that input.
Do you have any idea what your daughter did to the input exactly to fry it?
bhl
She put a screwdriver and damaged internally.
Like I said, even a dead short shouldn't have damaged the electronics.
What she may have actually done was simply damage the mechanical jack connector itself. Easy fix with a new connector and a soldering iron.
Otherwise, worst case scenario, it's possible that a static discharge fried an input transistor or buffer IC on the mainboard.
Either way, a GOOD tech should be able to do a component level repair without having to swap out the mainboard.
I'd say phone around the local music shops in your area and get a second opinion from their keyboard techs.
Selling you a new mainboard is like killing ants with a sledgehammer. Overkill.
PS. This is assuming that everything else is working normally as it should.
BTW, I really don't understand how Kurzweil tech support could definitively tell you the motherboard needed swapping from a phone call or an email.
Without looking at the actual hardware nobody could give you a specific diagnosis.
I'm disappointed in this level of support from Kurz. This is not up to their usual standard.
bhl
Ok, I will look for a second on maybe third diagnostic. Thanks for the help!
You're very welcome.
Hopefully it is only a damaged connector and won't cost you more than $100
Keep us posted.
Tampa Bay Area, Florida
I fully agree with Gary. Nobody can diagnose the problem without a physical check and it should not cost too much to have it repaired by a decent tech. I would be happy to tackle it at home, if it were mine.
Another option, give her a few years and your little daughter might just be up to doing the job for you! Starting off with a screwdriver at 2 years of age is impressive.
