Question.Increasing Chords & Note sizes in a Lead Sheet ?
Lincoln UK
MuseScore. In MuseScore I know how to increase Chord & Note sizes & Delete Words.
QUESTION. Do we have a PC program to do the same with Lead Sheets by increasing for larger view & Print Out.?
Lincoln UK
Col. PC. I can't appear to be able to load Lead Sheet PDF into MuseScore although it states you can.
You are supposed to be able to load PDF files direct from the file menu but not having used Muse Score not sure I can help.
if you have software like Publisher you could try importing your lead sheets into Publisher then exporting into a PDF and try loading that file, just in case it is a problem with the format of your original lead sheet.
