- Joined
- Nov 18, 2017
- Messages
- 18
- Reaction score
- 0
Hi,
I have been in contact with Yamaha as I have tried to load a saved registry from my USB stick as my memory bank is now full.
It says in the instruction booklet (page 86) I can load a saved registry from a USB stick to call up to play.
My keyboard is not doing that and so I thought the keyboard may have a fault.
Yamaha are telling me you can't load a registry direct from a USB which I think is incorrect.
If that is the case, then when you have filled your memory bank then there's no more you can do.
I thought the whole point of saving registry's on a USB stick was so they can be loaded to play when you like.
It does say that you can save up to 100 registries on s USB stick.
Is anyone else encountering this problem or am I correct in my thinking that even though my memory bank is full I should still be able to load up other saved registries from my USB stick?
