- Joined
- Jun 22, 2019
- Messages
- 9
- Reaction score
- 0
I have used MIDI to some extent over the years and have a basic level of knowledge. I have a Yamaha CLP – 170 that has both a disk drive and USB as well as MIDI in and out.
What I am attempting to do is archive songs played by a couple of my daughters. I want to come up with midi files. Of course I can do this using the 3 1/2 inch disc drives, but that requires some gymnastics as in cranking up the old gateway tower, copying the file to a portable storage device, loading that to my iMac, saving it to dropbox, then opening in Synthesia to play in the Yamaha if I want to record an audio track.
I am able to record MIDI into Garage Gand as well as studio one but there is not a simple way to export a MIDI file with those two.
I think that my old cakewalk on the gateway will do this but I don't really want to use it. So my question is, are there some good apps for iPad or iPhone that I can use to simply archive songs and create mid files?
