Speaker for a new keyboard
I'm buying a Roland VR-09 and wondering what kind of speaker to get with it? I need something under $200, just for home use, doesn't have to be that loud, but want it to sound good! Any suggestions? Thanks!!
PreSonus Eris 4.5 which retail for $200 US for a pair.
I have a pair and they perform well if lacking a bit in bass.
Checkout a Behringer B208D which retails at c$140 US each and others in this size range.
Thanks!! In the interest of saving space, would a single speaker on the floor work as well instead of two monitors that need to be on stands?
The floor away from a wall is the best place for a sub-woofer, all others are best on a stand or bracket, but I did have a pair of B208D powered monitors that lived on the floor at either end of the Zee stand and the sounded pretty good.
The Eris 4.5 that I referred to are very compact and live on a longish shelf behind my keyboard their combined size is probably about 1/2 that of a single B208D.
Michigan, US
You can also opt for a bluetooth speaker that, depending on your keyboard, could sit right in front of you. Most if not all have an option to use a cable instead of the BT.
Be careful using bluetooth.
The latency can and will kill your playing.
+1 Vote for the Presonus Eris Speakers. Best bang for the buck these days.
Michigan, US
"Be careful using bluetooth. The latency can and will kill your playing."
Absolutely, that's why it's important to get one that has an audio input. I have one made by JBL and Bose also have models that are within your budget and sound great for playing or practicing. I use monitor speakers for mixing and mastering but that's a whole other deal. If you think you will be using speakers for other than casual playing I would also recommend the Presonus.
