Sustain Pedal CTX3000
Just trying to connect a sustain pedal to the Casio ctx 3000 which is done successfully but every time I switch the keyboard off and back on again the settings are lost and I have to start again.
Is there a way for the setting to be retained?
Welcome.
Are you connecting the pedal to the Pedal 1 socket and following the instructions in the Manual which has a Long Press of the Exit button when you have set the configuration?
I am presuming the Long Press of the Exit button is the Save action.
Thanks for your comment Biggles I am using the long press of the exit button but I have the pedal connected to Pedal 2 socket - I got the impression from the manual that that Pedal 1 was for a Casio pedal and I am using a Stagg SUSPED 10
Hi Biggles, switched the jack to pedal 1 and followed the pedal 1 instructions and this has worked - now retained the setting.
Thanks again for your comments.
