Sustain pedal not working on my Alesis V49
I know next to nothing about MIDI. How do I get the sustain pedal working? The Alesis owners manual is not understandable by me. editor.jpg
Welcome.
You plug it in to the socket on the rear of the controller.
If you are using a non Alesis pedal do note that it may not be the correct type, ie normally open or normally closed.
Wow, treated like I'm an imbecile. Of course its plugged in! It doesn't work being plugged in. I can't figure out how to set it up in the editor. I have no clue what things like CC and channel and stuff like that are.
Well, I took the sustain pedal apart and it was broken on the inside. It was not a software or programming problem after all. Mechanical failure.
