to change the sustain pedal polarity in casio CTK5000
My sustain pedal is working in reveese polarity.....i.e. while pressing yhe pedal the notes are not suatained nut while leaving it it is suatained. Is there any possibility to reverse the polarity from the keyboard??
Welcome.
There is often a reverse polarity switch on a pedal so do have a floser look at yours.
Failing that within the menu there should be an option to change priority, your manual will advise.
KaveBB
