Trying to use Midi from DGX 660 for Musescore Input
ST AUGUSTINE
I am having no luck at all entering notes via the midi from my DGX 660 into Musescore. I have checked and the preferences does have Midi Keyboard turned on.
Has anyone had success with that? Suggestions?
[EDIT]
I just found a video on the topic, and not only do you need to turn on Midi for Note Input, but you also have to set the Midi Input under I/O. But when I try to do that, the pull down does not bring up a selection for me to use.
Also, BTW, I did have the keyboard on first before bringing up Musescore, which I understand is another requisite.
ST AUGUSTINE
Oh, another BTW: The midi does work on my DGX. I use Playground Sessions for learning, which works with hooking the midi up to the usb on the laptop, and it then shows what notes I am hitting, green when correct, red when wrong.
