Wanted 9AC123 cable
Hi all. Would anyone have a 9 AC123 cable for the Ketron X1 series to transfer files from the PC. I have lost mine and can't find one anywhere?? Cheers
Welcome, George! :D
Have you checked with Ketron forums? Search this forum for "Ketron" and you should find posts with links to some Ketron forums.
Welcome.
There are RS232 to USB cables on Amazon that could connect up OK but you probably would need to check that it is wired correctly.
Thanks Biggles for the info but I'm afraid it wouldn't work as the input on the X1 is a small round one called computer interface There's one on Thommans site I'll get it's bloody expensive, oh well need must huh? Cheers
