Wersi wing style conversions
Looking for a way to convert older .ste styles from Wersi Pegasus to work on newer Wersi Wing.
Wing only accepts styles with .stw, .sto, .sty, .sst or .prs extensions as stated in owners manual.
Any info on whether this can be done or any aftermarket software that can accomplish this would be apprecialted.
Thanks
phoenix
Thanks
Worth asking this question in an organ forum too. A quick google search will show the most obvious one out there (which I also use) they are equally helpful over on the organ forum. Good luck!
Yes. Know which one you are referring to. Seems like they are more concerned with converting from one manufacturer to another. Wasn't sure if they can convert from older to newer instruments with different extensions. Thanks for your response
