Whats better roland fantom x6 or yamaha mo8
Manchester, England.
Better for/at what?... you stand a much greater chance of replies if you're
prepared to go into a little more detail about what your requirements are!
Well for making music tracks like nine inch nails really layerd drum sounds with piano violin ect
I have songs someone sent me completely using a fantom and wondering if i could achieve the same sounds on mine
Newmarket, Ontario, Canada
Which is better? Hard to say; Fantom X was Roland's flagship before they introduced the Fantom G; MO8 is a scaled-down Motif ES. Still, the MO8 will probably do some sounds better and some sounds worse than the Fantom; the main difference will be in the features it has.
Can you make sounds like the ones your friend sent you? Try it and see!
alright cool so i can make real layerd nine inch nails type solo tracks with the mo8
