Yamaha compter program.
hello. i have yamaha PSR-1000. i can connect it to my compter, but what softwer do i need to work with?
thanks, trepoto
see ya.
mostly i want to record midis to the computer, and i want it to be in a good sound. can you help me?
If you want to transmit the MIDI signal (and just the MIDI signal) you'll need some type of MIDI editing/recording software. Something like Cubase or Nuendo. Those are expensive though...
I believe you want just to record your playing... and that is covered in my other topic.
