Yamaha E363 instrument definition file - where can I get one?
My daughter recently got a Yamaha E363, and has been playing around with it in conjunction with Cakewalk. She's using it as a MIDI input device, but she wants to be able to have MIDI output going into the keyboard so that she can use its internal sounds.
The trouble she has is that because we don't have an instrument definition for that keyboard, we can only use one that's "pretty close", and a lot of the patches don't match up. For example, many of the drum sounds play a different drum/percussion.
I've looked everywhere and I can't find an instrument definition file for it. I know that it's possible to create my own, but it looks like too much work.
Does anyone know where I can get one?
Visit the cakewalk forums to learn how to roll your own INI files.
Be sure and release your file to the community once you've created it.
I've done so with multiple instruments over the years.
