Yamaha keyboard grand piano’s dgx-640
Can anybody help me my keyboard does not make any sounds anymore and the screen is blue and I can’t do anything so if anyone knows a Solution because I really wanna play my keyboard again .
Try a factory reset.
Standard method is to hold down furthest white key whilst turning on the keyboard.
Do check what your manual states first and check in the Trouble shooting section.
If all else fails seek advice from a Tech as to repair costs.
You may also want to search the DGX threads for prior posts.
