yamaha mm6
how do i record patterns in cubase le from my yamaha mm6.
i downloaded the mm6 xml and i can see the instruments on it.
but dont know how to record a pattern.
please help...
thanks,
Tamir.
Cleveland
do you mean record a rhythm? i think you would have to do it the same way you would record anything else i don't think you can take the patterns off of it any other way. i think you can only do that with the motifs
Similar Threads
