Yamaha PSR-E373 question
Hi, will the PSR-E373 display the name of a triad I play on it ? For example Esus4 ?
I downloaded the manual but can't find an answer to the question.
If you play a chord in the Accompaniment Section (i.e., to the left of the Split Point) with Accompaniment turned on, the keyboard will show the name (or an abbreviation) of the chord-- but not if you play it to the right of the Split Point or with Accompaniment turned off.
Ok, got it. Thank you !
