I am getting a very little sound out of the monitors when i play the genos. Display is lighting up on the mixer and EQ when i play
Ok, I think you're going to want to set your white knob on the end (labeled Monitor) higher. I would use the main outs instead of the monitor outs though, because the monitor outs will be in Mono I think and the mains would be stereo, which is what you would want.
Man!... im going to take a break for dinner. This is frying my brains. I have switched everything off for now.Here's a screenshot of the manual.
It shows GRAPHICALLY what connects where.
If I'm right you have your inputs and outputs reversed!
Bad juju!!!
Gary![]()
I've never had that happen with this sort of setup, and I've made my fair share of mistakes in the past. Hopefully my video will help him.I'm worried that the only signal you are getting is crosstalk from a miswired system. MAKE DAMNSURE you have it wired up properly before you experiment with the power on.
Gary![]()
I really appreciate you taking the time to explain that all to me. I will have a go in a while and report back! thank you!Yes, the XLR pair at the top right and the 1/4" pair below that are both stereo outs. Here's how I would set it up (I have a different mixer, but this is approximately what you would want):
Sure! thank you so much Gary!It's 10 PM here. Good little rats need their sleep.
I'll get back to you tomorrow.
Gary![]()
Now the government can use their beard-hat-sword-and-shield recognition software to track you!![]()
Volume settings should be whatever sounds good to you. Just don't crank everything or you risk hearing damage. Glad we could help!
