Can I use Band in a box styles in AKX10 ?
I tried to install in Grand Suite but the message was format error. Same thing with USB stick to AKX10. The file extension is sty but somehow there is a problem. Would be nice to use BB styles because there is thousands of them ...
Woodstock, Georgia, USA
Hi Kimmo … I can give this a try but I doubt that I will have any better luck than you did. I really suggest you stick to Yamaha style files. If there are a thousand BIAB styles then there are a million Yamaha styles.
Mendelw
