I'm in the process of creating an Instrument Definition file for Cakewalk. It requires that the instrument names be organized by Bank Select number, so I made a list (with a lot of hand editing) with them sorted in that order.
This list can come in handy for any MIDI program in which you can create an Instrument Definition for it. I've not completed the .INS file for Cakewalk yet, just getting started. But in the meantime, attached is a zip file of that instrument list sorted by Bank number. (Okay, scratch that idea. This forum won't allow zip files to be uploaded. I guess I could just paste it all as text using the 'code' feature if anyone wants it. I'll do that instead.)
Far as I know, this list should be compatible with the CTK-4000, CTK-5000, and WK-500 as well (maybe others), as their specs are identical, and the 4000 and 5000 even share the same manual and appended info files.
One other thing I found interesting, for those of you who want to create your own Cakewalk .INS files. When it comes time to select (or create) a bank of "Controller Names" for these keyboards, just drag and drop the one named "Yamaha XG Controllers". When comparing the hex codes in the Casio MIDI Implementation info, to the (decimal) numbers in that file, they seem to be completely identical, across the board. Nice to know. (The MIDI Implementation doc also alludes to this being also true for other Casio models: LK-270, LK-205, WK-500, CDP-200R)
Update: Sorry, I made an error. The CTK-4000 has 570 tones, the CTK-5000 and WK-500 both have 670 tones, as are listed in this table. Though there's a good chance that much of this table will still be applicable to the 4000. Maybe some 4000 owner can check that and verify. The 4000 and 5000 only share the same manual, not identical tone lists.
Code:
Casio CTK-5000 & WK-500 Tones Sorted by Bank Number
(useful for creating Instrument Definition files)
No. Name Program Bank Poly Note
Change Max Range
526 GM PIANO 1 0 0 48 A
527 GM PIANO 2 1 0 48 A
528 GM PIANO 3 2 0 48 A
529 GM HONKY-TONK 3 0 24 A
530 GM E.PIANO 1 4 0 48 A
531 GM E.PIANO 2 5 0 48 A
532 GM HARPSICHORD 6 0 48 A
533 GM CLAVI 7 0 48 A
534 GM CELESTA 8 0 48 A
535 GM GLOCKENSPIEL 9 0 48 A
536 GM MUSIC BOX 10 0 24 A
537 GM VIBRAPHONE 11 0 48 A
538 GM MARIMBA 12 0 48 A
539 GM XYLOPHONE 13 0 48 A
540 GM TUBULAR BELL 14 0 48 A
541 GM DULCIMER 15 0 24 A
542 GM ORGAN 1 16 0 48 A
543 GM ORGAN 2 17 0 24 A
544 GM ORGAN 3 18 0 24 A
545 GM PIPE ORGAN 19 0 24 A
546 GM REED ORGAN 20 0 48 A
547 GM ACCORDION 21 0 24 A
548 GM HARMONICA 22 0 48 A
549 GM BANDONEON 23 0 24 A
550 GM NYLON STR.GUITAR 24 0 48 A
551 GM STEEL STR.GUITAR 25 0 48 A
552 GM JAZZ GUITAR 26 0 48 A
553 GM CLEAN GUITAR 27 0 48 A
554 GM MUTE GUITAR 28 0 48 A
555 GM OVERDRIVE GT 29 0 24 A
556 GM DISTORTION GT 30 0 48 A
557 GM GT HARMONICS 31 0 48 A
558 GM ACOUSTIC BASS 32 0 48 A
559 GM FINGERED BASS 33 0 48 A
560 GM PICKED BASS 34 0 48 A
561 GM FRETLESS BASS 35 0 48 A
562 GM SLAP BASS 1 36 0 48 A
563 GM SLAP BASS 2 37 0 48 A
564 GM SYNTH-BASS 1 38 0 48 A
565 GM SYNTH-BASS 2 39 0 48 A
566 GM VIOLIN 40 0 48 A
567 GM VIOLA 41 0 48 A
568 GM CELLO 42 0 48 A
569 GM CONTRABASS 43 0 48 A
570 GM TREMOLO STRINGS 44 0 48 A
571 GM PIZZICATO 45 0 48 A
572 GM HARP 46 0 48 A
573 GM TIMPANI 47 0 48 A
574 GM STRINGS 1 48 0 48 A
575 GM STRINGS 2 49 0 48 A
576 GM SYNTH-STRINGS 1 50 0 48 A
577 GM SYNTH-STRINGS 2 51 0 48 A
578 GM CHOIR AAHS 52 0 48 A
579 GM VOICE DOO 53 0 48 A
580 GM SYNTH-VOICE 54 0 48 A
581 GM ORCHESTRA HIT 55 0 24 A
582 GM TRUMPET 56 0 48 A
583 GM TROMBONE 57 0 48 A
584 GM TUBA 58 0 48 A
585 GM MUTE TRUMPET 59 0 48 A
586 GM FRENCH HORN 60 0 24 A
587 GM BRASS 61 0 48 A
588 GM SYNTH-BRASS 1 62 0 24 A
589 GM SYNTH-BRASS 2 63 0 24 A
590 GM SOPRANO SAX 64 0 48 A
591 GM ALTO SAX 65 0 48 A
592 GM TENOR SAX 66 0 48 A
593 GM BARITONE SAX 67 0 48 A
594 GM OBOE 68 0 48 A
595 GM ENGLISH HORN 69 0 48 A
596 GM BASSOON 70 0 48 A
597 GM CLARINET 71 0 48 A
598 GM PICCOLO 72 0 48 A
599 GM FLUTE 73 0 48 A
600 GM RECORDER 74 0 48 A
601 GM PAN FLUTE 75 0 48 A
602 GM BOTTLE BLOW 76 0 24 A
603 GM SHAKUHACHI 77 0 24 A
604 GM WHISTLE 78 0 48 A
605 GM OCARINA 79 0 48 A
606 GM SQUARE LEAD 80 0 24 A
607 GM SAW LEAD 81 0 24 A
608 GM CALLIOPE 82 0 24 A
609 GM CHIFF LEAD 83 0 24 A
610 GM CHARANG 84 0 24 A
611 GM VOICE LEAD 85 0 24 A
612 GM FIFTH LEAD 86 0 24 A
613 GM BASS+LEAD 87 0 24 A
614 GM FANTASY 88 0 24 A
615 GM WARM PAD 89 0 48 A
616 GM POLYSYNTH 90 0 24 A
617 GM SPACE CHOIR 91 0 24 A
618 GM BOWED GLASS 92 0 24 A
619 GM METAL PAD 93 0 24 A
620 GM HALO PAD 94 0 24 A
621 GM SWEEP PAD 95 0 24 A
622 GM RAIN DROP 96 0 24 A
623 GM SOUND TRACK 97 0 24 A
624 GM CRYSTAL 98 0 24 A
625 GM ATMOSPHERE 99 0 24 A
626 GM BRIGHTNESS 100 0 24 A
627 GM GOBLINS 101 0 24 A
628 GM ECHOES 102 0 24 A
629 GM SF 103 0 24 A
630 GM SITAR 104 0 48 A
631 GM BANJO 105 0 48 A
632 GM SHAMISEN 106 0 48 A
633 GM KOTO 107 0 48 A
634 GM THUMB PIANO 108 0 48 A
635 GM BAGPIPE 109 0 24 A
636 GM FIDDLE 110 0 48 A
637 GM SHANAI 111 0 48 A
638 GM TINKLE BELL 112 0 48 A
639 GM AGOGO 113 0 48 A
640 GM STEEL DRUMS 114 0 24 A
641 GM WOOD BLOCK 115 0 48 D
642 GM TAIKO 116 0 48 D
643 GM MELODIC TOM 117 0 48 D
644 GM SYNTH-DRUM 118 0 48 D
645 GM REVERSE CYMBAL 119 0 48 D
646 GM GT FRET NOISE 120 0 48 A
647 GM BREATH NOISE 121 0 48 A
648 GM SEASHORE 122 0 24 D
649 GM BIRD 123 0 24 D
650 GM TELEPHONE 124 0 48 D
651 GM HELICOPTER 125 0 48 D
652 GM APPLAUSE 126 0 24 D
653 GM GUNSHOT 127 0 48 D
003 GRAND PIANO 0 1 48 A
007 BRIGHT PIANO 1 1 48 A
019 ELEC.GRAND PIANO 2 1 24 A
032 DYNO ELEC.PIANO 1 4 1 48 A
028 FM ELEC.PIANO 1 5 1 48 A
023 HARPSICHORD 2 6 1 24 A
050 CLAVI 2 7 1 48 A
063 BRIGHT CELESTA 8 1 48 A
067 MUSIC BOX 2 10 1 24 A
057 VIBRAPHONE 2 11 1 48 A
070 DULCIMER 15 1 24 A
072 DRAWBAR ORGAN 2 16 1 48 A
077 PERC.ORGAN 2 17 1 24 A
086 ROCK ORGAN 2 18 1 48 A
102 PIPE ORGAN 1 19 1 24 A
110 ACCORDION 3 21 1 48 A
119 HARMONICA 2 22 1 24 A
114 BANDONEON 2 23 1 48 A
122 NYLON STR.GUITAR 2 24 1 48 C
125 STEEL STR.GUITAR 2 25 1 48 C
133 JAZZ GUITAR 2 26 1 24 C
136 CLEAN GUITAR 2 27 1 48 C
141 MUTE GUITAR 2 28 1 48 C
144 OVERDRIVE GT 2 29 1 48 C
146 DISTORTION GT 2 30 1 24 C
160 ACOUSTIC BASS 2 32 1 48 C
163 FINGERED BASS 2 33 1 48 C
169 PICKED BASS 2 34 1 48 C
173 FRETLESS BASS 2 35 1 48 C
181 SAW SYNTH-BASS 38 1 24 C
182 SQUARE SYNTH-BASS 39 1 48 C
206 STRING QUARTET 40 1 24 A
201 SLOW CELLO 42 1 48 C
208 OCTAVE PIZZICATO 45 1 24 A
210 HARP 2 46 1 48 A
213 STRING ENSEMBLE 1 48 1 48 A
217 SLOW STRINGS 2 49 1 48 A
231 70's SYNTH-STR.1 50 1 48 A
230 SYNTH-STRINGS 3 51 1 48 A
240 CHOIRS 1 52 1 48 A
251 SYNTH-VOICE 2 54 1 48 A
259 ORCHESTRA HIT 2 55 1 48 A
263 TRUMPET 2 56 1 48 A
270 TROMBONE 2 57 1 48 C
280 FRENCH HORN SECTION 60 1 24 C
283 STEREO BRASS 61 1 24 A
298 80's SYNTH-BRASS 62 1 24 A
314 SOPRANO SAX 2 64 1 48 A
306 ALTO SAX 2 65 1 48 C
310 TENOR SAX 2 66 1 48 C
317 BARITONE SAX 2 67 1 48 C
328 VELO.CLARINET 71 1 48 A
341 PICCOLO 2 72 1 24 B
336 FLUTE 2 73 1 24 A
346 RECORDER 2 74 1 48 A
348 PAN FLUTE 2 75 1 24 A
354 SQUARE LEAD 2 80 1 24 A
358 SAW LEAD 2 81 1 48 A
380 VENT SYNTH 82 1 24 A
386 EP LEAD 83 1 24 A
393 OCTAVE CHARANG 84 1 24 A
388 VOICE LEAD 2 85 1 24 A
407 FIFTH SEQUENCE 86 1 24 A
409 BASS+SAW LEAD 87 1 24 A
414 FANTASY 2 88 1 24 A
418 THICK PAD 89 1 24 A
425 POLYSYNTH 2 90 1 24 A
430 HEAVEN 91 1 24 A
434 SQUARE PAD 92 1 24 A
438 TINE PAD 93 1 24 A
442 CHORUS PAD 94 1 24 A
446 SWEEP CHOIR 95 1 24 A
448 CLAVI PAD 96 1 24 A
452 SPACE VOICE 97 1 24 A
456 SOFT CRYSTAL 98 1 24 A
463 CELESTA PAD 99 1 24 A
467 BRIGHT BELL PAD 100 1 24 A
471 ECHO VOICE 102 1 24 A
476 STAR THEME 2 103 1 24 A
492 SITAR 2 104 1 24 A
519 MUTE BANJO 105 1 48 A
001 STEREO GRAND PIANO 0 2 24 A
002 STEREO BRIGHT PIANO 1 2 24 A
020 E.GRAND 80 2 2 48 A
016 HONKY-TONK 3 2 24 A
026 ELEC.PIANO 1 4 2 48 A
027 ELEC.PIANO 2 5 2 24 A
022 HARPSICHORD 1 6 2 48 A
049 CLAVI 1 7 2 48 A
062 CELESTA 8 2 48 A
064 GLOCKENSPIEL 9 2 48 B
066 MUSIC BOX 1 10 2 24 A
056 VIBRAPHONE 1 11 2 48 A
060 MARIMBA 12 2 48 A
068 XYLOPHONE 13 2 48 A
069 TUBULAR BELL 14 2 48 A
071 DRAWBAR ORGAN 1 16 2 48 A
076 PERC.ORGAN 1 17 2 48 A
085 ROCK ORGAN 1 18 2 24 A
099 CHURCH ORGAN 1 19 2 24 A
107 REED ORGAN 20 2 48 A
108 ACCORDION 1 21 2 24 A
118 HARMONICA 1 22 2 48 A
113 BANDONEON 1 23 2 24 A
121 NYLON STR.GUITAR 1 24 2 48 C
124 STEEL STR.GUITAR 1 25 2 48 C
132 JAZZ GUITAR 1 26 2 48 C
135 CLEAN GUITAR 1 27 2 48 C
140 MUTE GUITAR 1 28 2 48 C
143 OVERDRIVE GT 1 29 2 24 C
145 DISTORTION GT 1 30 2 48 C
159 ACOUSTIC BASS 1 32 2 48 C
162 FINGERED BASS 1 33 2 48 C
168 PICKED BASS 1 34 2 48 C
172 FRETLESS BASS 1 35 2 48 C
174 SLAP BASS 1 36 2 48 C
175 SLAP BASS 2 37 2 48 C
177 SYNTH-BASS 1 38 2 48 C
178 SYNTH-BASS 2 39 2 48 C
197 VIOLIN 40 2 48 A
199 VIOLA 41 2 48 A
200 CELLO 42 2 48 C
202 CONTRABASS 43 2 48 C
224 TREMOLO STRINGS 44 2 48 A
207 PIZZICATO STRINGS 45 2 48 A
209 HARP 1 46 2 48 A
212 STRINGS 48 2 48 A
216 SLOW STRINGS 1 49 2 48 A
228 SYNTH-STRINGS 1 50 2 48 A
229 SYNTH-STRINGS 2 51 2 48 A
239 CHOIR AAHS 52 2 48 A
248 VOICE DOO 53 2 48 A
250 SYNTH-VOICE 1 54 2 48 A
258 ORCHESTRA HIT 1 55 2 24 A
262 TRUMPET 1 56 2 48 A
269 TROMBONE 1 57 2 48 C
276 TUBA 1 58 2 48 C
268 MUTE TRUMPET 59 2 48 A
278 FRENCH HORN 60 2 24 C
284 BRASS 61 2 48 A
293 SYNTH-BRASS 1 62 2 24 A
294 SYNTH-BRASS 2 63 2 24 A
313 SOPRANO SAX 1 64 2 48 A
305 ALTO SAX 1 65 2 48 C
309 TENOR SAX 1 66 2 48 C
316 BARITONE SAX 1 67 2 48 C
331 OBOE 68 2 48 A
333 ENGLISH HORN 69 2 48 A
334 BASSOON 70 2 48 C
327 CLARINET 71 2 48 A
340 PICCOLO 1 72 2 24 B
335 FLUTE 1 73 2 48 A
345 RECORDER 1 74 2 48 A
347 PAN FLUTE 1 75 2 48 A
349 BOTTLE BLOW 76 2 24 A
352 SHAKUHACHI 77 2 24 A
350 WHISTLE 78 2 48 A
351 OCARINA 79 2 48 A
353 SQUARE LEAD 1 80 2 24 A
357 SAW LEAD 1 81 2 24 A
377 CALLIOPE 1 82 2 24 A
384 CHIFF LEAD 83 2 24 A
392 CHARANG 84 2 24 A
387 VOICE LEAD 1 85 2 24 A
402 FIFTH LEAD 86 2 24 A
408 BASS+LEAD 87 2 24 A
413 FANTASY 1 88 2 24 A
419 WARM PAD 89 2 48 A
424 POLYSYNTH 1 90 2 24 A
429 SPACE CHOIR 91 2 24 A
435 BOWED PAD 92 2 24 A
440 SOFT METAL PAD 93 2 24 A
443 HALO PAD 1 94 2 24 A
447 SWEEP PAD 95 2 24 A
449 RAIN DROP 1 96 2 24 A
453 SOUND TRACK 1 97 2 24 A
457 CRYSTAL 98 2 24 A
464 ATMOSPHERE 99 2 24 A
468 BRIGHTNESS 1 100 2 24 A
470 GOBLIN 101 2 24 A
472 ECHO PAD 102 2 24 A
475 STAR THEME 1 103 2 24 A
491 SITAR 1 104 2 48 A
518 BANJO 105 2 48 A
523 SHAMISEN 106 2 48 A
524 KOTO 107 2 48 A
520 THUMB PIANO 108 2 48 A
502 SHANAI 111 2 48 A
521 STEEL DRUMS 114 2 24 A
006 STEREO MELLOW PIANO 0 3 24 A
005 ROCK PIANO 1 3 24 A
021 MODERN E.G.PIANO 2 3 24 A
033 DYNO ELEC.PIANO 2 4 3 24 A
029 FM ELEC.PIANO 2 5 3 24 A
051 SOFT CLAVI 7 3 48 A
065 GLOCKENSPIEL PAD 9 3 24 A
058 SOFT VIBRAPHONE 11 3 48 A
061 SOFT MARIMBA 12 3 48 A
073 DRAWBAR ORGAN 3 16 3 48 A
082 JAZZ ORGAN 1 17 3 24 A
087 ROCK ORGAN 3 18 3 24 A
100 CHURCH ORGAN 2 19 3 24 A
109 ACCORDION 2 21 3 24 A
120 HARMONICA 3 22 3 24 A
116 BANDONEON SOLO 23 3 24 A
126 STEEL STR.GUITAR 3 25 3 48 C
137 CLEAN GUITAR 3 27 3 24 C
147 DISTORTION GT 3 30 3 48 C
161 RIDE BASS 32 3 24 C
164 FINGERED BASS 3 33 3 48 C
170 PICKED BASS 3 34 3 48 C
176 DOUBLED STRINGS BASS 37 3 24 C
187 VOCODER BASS 38 3 48 C
183 DIGI ROCK BASS 39 3 48 C
205 VIOLIN & CELLO 40 3 24 A
214 STRING ENSEMBLE 2 48 3 48 A
225 HARP & STRINGS 49 3 24 A
233 80's SYNTH-STR.1 50 3 48 A
241 CHOIRS 2 52 3 24 A
249 VOICE UUH 53 3 48 A
252 SYNTH-VOICE 3 54 3 48 A
260 ORCHESTRA HIT 3 55 3 24 A
264 TRUMPET 3 56 3 48 A
271 MELLOW TROMBONE 57 3 48 C
277 TUBA 2 58 3 48 C
279 FRENCH HORN SOLO 60 3 48 C
285 BRASS SECTION 1 61 3 24 A
295 SYNTH-BRASS 3 62 3 48 A
296 SYNTH-BRASS 4 63 3 48 A
319 HARD A.SAX 65 3 24 C
330 JAZZ CLARINET 71 3 48 A
337 JAZZ FLUTE 73 3 24 A
355 SQUARE LEAD 3 80 3 48 A
359 SAW LEAD 3 81 3 48 A
378 CALLIOPE 2 82 3 24 A
394 PLUCK LEAD 1 84 3 24 A
397 CHURCH LEAD 85 3 24 A
404 FIFTH SQUARE LEAD 86 3 24 A
410 SYNTH-BASS+LEAD 87 3 24 A
415 NEW AGE 88 3 24 A
420 SINE PAD 89 3 24 A
426 POLYSYNTH PAD 1 90 3 24 A
431 SPACE STRINGS PAD 91 3 24 A
436 GLASS PAD 92 3 24 A
441 HARD METAL PAD 93 3 24 A
444 HALO PAD 2 94 3 24 A
450 RAIN DROP 2 96 3 24 A
454 SOUND TRACK 2 97 3 24 A
458 CHRISTMAS BELL 98 3 24 A
466 STEEL PAD 99 3 24 A
469 BRIGHTNESS 2 100 3 24 A
473 ECHO DROP 102 3 24 A
493 SITAR PAD 104 3 24 A
525 KOTO PAD 107 3 24 A
004 CLASSIC PIANO 0 4 24 A
008 MODERN PIANO 1 4 24 A
030 60's ELEC.PIANO 1 4 4 48 A
039 MODERN E.PIANO 5 4 24 A
025 HARPSICHORD & STRINGS 6 4 24 A
052 DETUNE CLAVI 7 4 24 A
079 ELEC.ORGAN 1 16 4 48 A
083 JAZZ ORGAN 2 17 4 24 A
090 ROTARY ORGAN 1 18 4 48 A
103 PIPE ORGAN 2 19 4 24 A
111 ACCORDION 4 21 4 24 A
117 BANDONEON & VIOLIN 23 4 24 A
127 12 STR.GUITAR 25 4 24 C
138 CLEAN GUITAR 4 27 4 24 C
148 DISTORTION GT 4 30 4 24 C
167 MELLOW FINGERED BASS 33 4 48 C
171 RHYTHM PICKED BASS 34 4 48 C
184 TRANCE BASS 38 4 48 C
185 SINE BASS 39 4 48 A
203 VIOLIN SECTION 40 4 24 A
204 CELLO SECTION 42 4 24 C
215 STRING ENSEMBLE 3 48 4 48 A
226 FLUTE & STRINGS 49 4 24 A
232 70's SYNTH-STR.2 50 4 48 A
242 CHOIR STRINGS 52 4 24 A
253 VOICE ENSEMBLE 1 54 4 24 A
261 ORCHESTRA HIT 4 55 4 24 A
265 MELLOW TRUMPET 56 4 48 A
272 VELO.TROMBONE 57 4 48 C
281 OCTAVE FRENCH HORN 60 4 24 C
286 BRASS SECTION 2 61 4 24 A
299 ANALOG SYNTH-BRASS 1 62 4 48 A
301 TRANCE BRASS 63 4 24 A
320 SOLO A.SAX 65 4 48 C
322 SOLO T.SAX 66 4 48 C
332 SOLO OBOE 68 4 48 A
329 BASS CLARINET 71 4 48 C
342 PIPE SECTION 1 72 4 24 A
338 PURE FLUTE 73 4 24 A
356 SQUARE LEAD 4 80 4 48 A
367 SS LEAD 81 4 24 A
381 PURE LEAD 82 4 24 A
385 DROP LEAD 83 4 24 A
395 PLUCK LEAD 2 84 4 24 A
399 VOICE CHOIR LEAD 85 4 24 A
403 FIFTH SAW LEAD 86 4 24 A
411 REED LEAD 87 4 24 A
416 NEW AGE PAD 88 4 24 A
421 SOFT PAD 89 4 24 A
427 POLYSYNTH PAD 2 90 4 24 A
432 CHIFF CHOIR 91 4 24 A
437 BOTTLE PAD 92 4 24 A
439 ETHNIC PAD 93 4 24 A
445 ORGAN CHOIR PAD 94 4 24 A
451 WOOD PAD 96 4 24 A
459 GLOCKENSPIEL CHIME 98 4 24 A
465 NYLON GT & EP 99 4 24 A
474 POLY DROP 102 4 24 A
011 MELLOW PIANO 0 5 48 A
010 DANCE PIANO 1 5 48 A
031 60's ELEC.PIANO 2 4 5 48 A
035 POP ELEC.PIANO 5 5 24 A
053 SEQUENCE CLAVI 7 5 24 A
080 ELEC.ORGAN 2 16 5 48 A
095 8'ORGAN 17 5 24 A
101 CHAPEL ORGAN 19 5 48 A
123 NYLON GT + STRUM.NOISE 24 5 48 C
128 STEEL GT + STRUM.NOISE 1 25 5 48 C
139 CHORUS CLEAN GUITAR 27 5 48 C
149 POWER DIST.GT 30 5 24 C
166 RHYTHM FINGERED BASS 33 5 48 C
188 SOUL SYNTH-BASS 38 5 48 C
186 BASS & KICK 39 5 24 C
219 CHAMBER 1 48 5 24 A
234 80's SYNTH-STR.2 50 5 24 A
243 STRINGS VOICE 52 5 24 A
254 VOICE ENSEMBLE 2 54 5 24 A
266 VELO.TRUMPET 56 5 48 A
273 TROMBONE SECTION 57 5 24 C
282 HORN ORCHESTRA 60 5 24 C
287 BRASS SECTION 3 61 5 24 A
300 ANALOG SYNTH-BRASS 2 62 5 24 A
302 SYNTH-BRASS PAD 63 5 24 A
318 SOFT A.SAX 65 5 48 C
321 SOFT T.SAX 66 5 48 C
339 SOFT FLUTE 73 5 24 A
368 SLOW SQUARE LEAD 80 5 24 A
374 PULSE SAW LEAD 81 5 24 A
379 VENT LEAD 82 5 24 A
383 SEQUENCE LEAD 83 5 24 A
396 GT SYNTH-LEAD 84 5 24 A
400 EP & VOICE LEAD 85 5 24 A
405 FOURTH LEAD 86 5 24 A
412 FRET LEAD 87 5 24 A
422 HORN PAD 89 5 24 A
433 STAR VOICE 91 5 24 A
460 VIBRAPHONE BELL 98 5 24 A
009 LA PIANO 1 6 48 A
036 CHORUS EP 1 4 6 48 A
048 HARPSICHORD E.PIANO 5 6 24 A
054 CLAVI & DRAWBAR 7 6 24 A
081 ELEC.ORGAN 3 16 6 48 A
088 70's ORGAN 17 6 48 A
104 THEATER ORGAN 19 6 24 A
129 STEEL GT + STRUM.NOISE 2 25 6 48 C
142 CRUNCH ELEC.GUITAR 27 6 48 C
150 RHYTHM DIST.GT 30 6 24 C
165 FINGERED BASS 4 33 6 48 C
179 SYNTH-BASS 3 38 6 24 C
180 SYNTH-BASS 4 39 6 24 C
220 CHAMBER 2 48 6 24 A
235 FAST SYNTH-STRINGS 50 6 48 A
246 CHOIRS ENSEMBLE 1 52 6 24 A
255 VOICE ENSEMBLE 3 54 6 24 A
275 TRUMPET & TROMBONE 56 6 24 A
274 JAZZ TROMBONE 57 6 48 C
288 MELLOW BRASS 61 6 48 A
303 OCTAVE SYNTH-BRASS 62 6 24 A
344 FLUTE & OBOE 73 6 24 A
369 SLOW SQUARE PULSE 80 6 24 A
373 SLOW SAW LEAD 81 6 24 A
382 PIPE LEAD 82 6 24 A
401 SYNTH-VOICE LEAD 85 6 24 A
406 SEVENTH SEQUENCE 86 6 24 A
423 OLD TAPE PAD 89 6 24 A
461 CHORAL BELL 98 6 24 A
037 CHORUS EP 2 4 7 48 A
055 CHORUS CLAVI 7 7 48 A
089 FULL DRAWBAR 16 7 48 A
078 PERC.ORGAN 3 17 7 24 A
105 ORGAN & HARPSICHORD 19 7 24 A
130 STEEL GT HARMONICS 25 7 24 C
152 DIST.GT & BASS 30 7 24 C
223 STRINGS SFZ 48 7 48 A
236 SLOW SYNTH-STRINGS 50 7 48 A
247 CHOIRS ENSEMBLE 2 52 7 24 A
289 HARD BRASS 61 7 24 A
297 WARM SYNTH-BRASS 62 7 24 A
324 A.SAXYS 65 7 24 C
323 T.SAXYS 66 7 24 C
361 SQUARE PULSE LEAD 80 7 24 A
375 SLOW SAW PULSE 81 7 24 A
398 DOUBLE VOICE LEAD 85 7 24 A
462 SYNTH-MALLET 98 7 24 A
012 STRINGS PIANO 0 8 24 A
014 SYNTH-STR.PIANO 1 8 24 A
017 2 OCTAVE PIANO 3 8 24 A
041 STRINGS E.PIANO 1 4 8 24 A
042 STRINGS E.PIANO 2 5 8 24 A
024 COUPLED HARPSICHORD 6 8 24 A
059 CHORUS VIBRAPHONE 11 8 24 A
074 DRAWBAR ORGAN 4 16 8 48 A
084 JAZZ ORGAN 3 17 8 24 A
106 PIPE ORGAN PAD 19 8 24 A
112 OCTAVE ACCORDION 21 8 24 A
115 OCTAVE BANDONEON 23 8 24 A
134 OCT JAZZ GUITAR 26 8 24 C
151 FEEDBACK GT 31 8 24 C
198 SLOW VIOLIN 40 8 48 A
211 CHORUS HARP 46 8 24 A
221 OCTAVE STRINGS 1 48 8 24 A
237 OCTAVE SYNTH-STRINGS 1 51 8 24 A
244 CHORUS CHOIR 52 8 48 A
256 SYNTH-VOICE PAD 54 8 48 A
267 TRUMPET SFZ 56 8 48 A
292 BRASS & SAX 61 8 24 A
304 SYNTH-BRASS SFZ 62 8 48 A
315 BREATHY S.SAX 64 8 24 A
307 BREATHY ALTO SAX 1 65 8 24 C
311 BREATHY TENOR SAX 1 66 8 24 C
343 PIPE SECTION 2 73 8 24 A
365 SINE LEAD 80 8 48 A
360 MELLOW SAW LEAD 81 8 24 A
391 DISTORTION LEAD 84 8 24 A
389 VOX LEAD 1 85 8 24 A
417 WARM VOX 89 8 24 A
428 POLY SAW 90 8 24 A
455 RAVE 97 8 24 A
477 SPACE PAD 103 8 24 A
522 RABAB 105 8 24 A
013 PIANO PAD 0 9 24 A
018 1 OCTAVE PIANO 3 9 24 A
043 SYNTH-STR.E.PIANO 1 4 9 24 A
044 SYNTH-STR.E.PIANO 2 5 9 24 A
075 DRAWBAR ORGAN 5 16 9 48 A
091 ROTARY ORGAN 2 17 9 24 A
222 OCTAVE STRINGS 2 48 9 24 A
238 OCTAVE SYNTH-STRINGS 2 51 9 24 A
245 SLOW CHOIR 52 9 48 A
257 CHORUS SYNTH-VOICE 54 9 48 A
290 BRASS SFZ 61 9 24 A
308 BREATHY ALTO SAX 2 65 9 24 C
312 BREATHY TENOR SAX 2 66 9 24 C
366 VELO.SINE LEAD 80 9 48 A
376 TRANCE LEAD 81 9 24 A
390 VOX LEAD 2 85 9 24 A
015 CHOIR PIANO 0 10 24 A
046 E.PIANO PAD 2 4 10 24 A
045 E.PIANO PAD 1 5 10 24 A
096 ORGAN PAD 1 16 10 48 A
092 ROTARY ORGAN 3 17 10 24 A
189 CLAVI BASS 39 10 24 C
227 ORCHESTRA STRINGS 48 10 24 A
291 BRASS & STRINGS 61 10 24 A
325 SAX SECTION 65 10 24 C
364 SEQUENCE SINE 80 10 48 A
362 SEQUENCE SAW 1 81 10 24 A
034 MELLOW E.PIANO 4 11 24 A
097 ORGAN PAD 2 16 11 48 A
094 CLICK ORGAN 17 11 48 A
190 ORGAN BASS 39 11 48 A
218 WIDE STRINGS 48 11 24 A
326 SAX SECTION SFZ 65 11 24 C
370 SEQUENCE SQUARE 80 11 24 A
363 SEQUENCE SAW 2 81 11 24 A
038 TREMOLO E.PIANO 4 12 48 A
093 TREMOLO ORGAN 16 12 48 A
098 SEQUENCE ORGAN 17 12 24 A
131 CHORUS STEEL GT 25 12 48 C
371 SEQUENCE PULSE 1 80 12 24 A
040 SOFT E.PIANO 4 13 24 A
372 SEQUENCE PULSE 2 80 13 24 A
047 CLEAN E.PIANO 4 14 48 A
481 YANG QIN 1 15 16 48 A
516 ARABIC ORGAN 16 16 24 A
496 HARMONIUM 1 20 16 48 A
517 ARABIC STRINGS 48 16 24 A
483 DI ZI 72 16 48 A
487 XIAO 77 16 24 A
494 TANPURA 1 104 16 48 A
488 PI PA 1 105 16 48 A
484 ZHENG 107 16 24 A
485 SHENG 109 16 48 A
478 ER HU 1 110 16 24 A
486 SUO NA 111 16 48 A
505 TABLA 116 16 48 A
482 YANG QIN 2 15 17 24 A
497 HARMONIUM 2 20 17 24 A
510 NEY 1 72 17 48 A
495 TANPURA 2 104 17 24 A
489 PI PA 2 105 17 24 A
479 ER HU 2 110 17 24 A
498 SANTUR 1 15 18 24 A
511 NEY 2 72 18 24 A
500 SAROD 1 105 18 48 A
480 ER HU 3 110 18 24 A
514 ZURNA 111 18 48 A
499 SANTUR 2 15 19 24 A
501 SAROD 2 105 19 48 A
490 YANG QIN & ER HU 110 19 24 A
506 KANUN 1 15 20 48 A
508 OUD 1 105 20 48 A
503 SARANGI 1 110 20 48 A
507 KANUN 2 15 21 24 A
509 OUD 2 105 21 48 A
504 SARANGI 2 110 21 48 A
513 SAZ 105 22 48 A
512 KEMENCHE 110 22 48 A
515 BOUZOUKI 105 23 48 A
153 STEEL GT + STRUM.NOISE M 1 25 32 48 A
155 CLEAN GUITAR M 27 32 48 A
158 DISTORTION GT M 29 32 24 A
191 FINGERED BASS M 1 33 32 48 A
193 PICKED BASS M 34 32 48 A
194 TRANCE BASS M 38 32 48 A
196 SQUARE SYNTH-BASS M 39 32 48 A
154 STEEL GT + STRUM.NOISE M 2 25 33 48 A
156 CRUNCH ELEC.GUITAR M 1 27 33 48 A
192 FINGERED BASS M 2 33 33 48 A
195 SAW SYNTH-BASS M 38 33 24 A
157 CRUNCH ELEC.GUITAR M 2 27 34 24 A
671 SAMPLED TONE 1 0 96 48 A
672 SAMPLED TONE 2 1 96 48 A
673 SAMPLED TONE 3 2 96 48 A
674 SAMPLED TONE 4 3 96 48 A
675 SAMPLED TONE 5 4 96 48 A
654 STANDARD SET 1 0 120 -- D
655 STANDARD SET 2 1 120 -- D
656 STANDARD SET 3 2 120 -- D
657 STANDARD SET 4 3 120 -- D
658 ROOM SET 8 120 -- D
659 HIP-HOP SET 9 120 -- D
660 POWER SET 16 120 -- D
661 ROCK SET 17 120 -- D
662 ELECTRONIC SET 24 120 -- D
663 SYNTH SET 1 25 120 -- D
664 SYNTH SET 2 30 120 -- D
665 TRANCE SET 31 120 -- D
666 JAZZ SET 32 120 -- D
667 BRUSH SET 40 120 -- D
668 ORCHESTRA SET 48 120 -- D
669 ETHNIC SET 1 49 120 -- D
670 ETHNIC SET 2 50 120 -- D
676 SAMPLED DRUM SET 1 96 120 -- D
677 SAMPLED DRUM SET 2 97 120 -- D
678 SAMPLED DRUM SET 3 98 120 -- D
