Desktop Syths? which to go for
Ha most of it is personal.
If i can cover depeche mode, Duran Duran, pink Floyd, and dreamy ambient stuff I'll be happy.
Understood. :)
I went thru my phase of looking for unique and eerie sounds to add to my palette as well :D
Remember, you need a Blofeld to go with it ;)
Screw the kids' college fund!!! Daddy needs his gear fix. :D
I hope you realise just how much of my Pension you are spending for me!
If I spend any more on keyboards I will not be able to buy any Tena pads for men which means it could get a bit uncomfortable.
:confused:
I think Peak might be the answer......
Got to try one for a couple of hours today. Sounds lovely, has FM and some Wave table (if not brilliant) stuff. 3 Oscillators is better than the Rev 2's 2. Compared to the REv 2, the Peak has less FX, but they can all be applied at once (the Rev 2 only has one FX per voice).
The only real dowside compared to the REv 2, from what I could see are:
1. Modulators....The Rev 2 has 4 x LFOs and 1 x Env. The {Peak has 2 Env but only 2 LFOs - one of which is hard wired to the Osc Pitch mod if want to use that).
2. Mod Matrix - The Rev 2 allows modulation of FX parameters, the Peak doesnt.
BUT - heres the kicker. Ive just spoken to a Beta tester for Peaks FW update. The new update adds the ability to Modulate FX parameters, AND adds 2 more LFOs (so 4 LFOs and 2 Mod Envelopes) as well as a much more in depth wavetable selection. Add in the FM on the peak and the £100 lower price tag (recent drop over the last week) and its looking VERY tempting.
peegeebee
