I got an old accordion from the 70's/80's with midi.
The midi is installed later and uses a 5pin connection (only 3 pins has wires inside: Shield/power/data)
I wanted to get this to work, inside FL studio, but cant get it work.
Im using a USB-MIDI cable, and it seems i cant even get any software to register buttons at all.
The instrument has installed a small display and 8 buttons, where the display is supposed to show numbers.
However the display doesnt even turn on, and the cable is showing a light for "Power", but no light for in/out
I tried to scroll through channels inside the FL studio output section, when i have the usb driver chosen,
and the blue "out" light on the cable flashes quickly and goes dim.
I cant get the green light (IN) to flash or light at all.
The midi interface just says "RMS-MIDI" and nothing more.
Any ideas on how i can get this working, would be super fun.
