Hello!
Apologies in advance for the noob question but I wanted to check before ordering, just in case I'm missing anything!
My keyboard is 130 cm wide and the stand I'm looking to buy is only 100cm wide, so there'll be a 15cm overhang on each side.
The keyboard weighs 15kg so I think it'll be study enough - does anyone have experience of either why this may be a bad idea, or some reassurance that's it's pretty standard?
Also, there's no screw fixes - should I also be looking at makeshift fittings like rubber pads or anything, or is the weight generally enough to prevent any movement whilst playing?
Thanks!
Thanks!
