Hi,
I am using main keyboard Kurzweil PC3 Le8 and Roland A33 (76 keys) controlling Yamaha MU100R, Yamaha VL7 and EMU B3.
Yamaha MU100R died now (not possible o repair) and I plan to change my rig to keep Kurzweil PC3Le8 and replace A33+modules with 2nd keyboard with sounds. my 2 favorite options are Korg Krome EX 73 or Korg Nautilus 61. I have read a lot about both, but have not tried personally.
I can live without many features on Nautilus (audio recording, sampling, sequencer, sound tweaking), my main concern is sound and keybed quality (use to play fast lead solos on 2nd keyboard)
I need to have wide range of sounds (presets) to choose from rather than do sound design by myself. Our band is playing prog-metal.
For home recording I am using DAW, so my main focus is "live gigs".
So the question is: are the presets on Korg Krome EX and Nautilus about the same quality (mainly leads, hammond, brass)? Is the keybed (semi-weighted) of both also similar?
As I have not bought any instrument for couple of years, the budget is not issue now.
Looking forward to your comments.
Petr
(Kurzweil Pc3-Le8, Roland A33, Yamaha MU100R, Yamaha VL7+BC3, EMU-B3)
Petr
