Need Article: Controller > Module > DAW
Again. I have skype. Skype ID happyrat1
Also, I have magicjack. Crazy cheap rates to UK landlines. Like 4 cents a minute.
Let's try and turn this into a REAL tech support session.
I'm attaching the cakewalk INS file for the SD2.
Unzip it and import it into your cakewalk instruments.
Use the Define Button on Page 2
You NEED this file.
  • Ketron SD2-ins.zip
And BTW, NONE of this will make a sound until you set up a track with the controller as input on MIDI Omni and select a Ketron voice for the track and enable the red R button on the track to record.
Gary,
BTW, if you want to just make noises on the fly and jam look up and install a program called MIDI Yoke. It's freeware.
http://www.midiox.com/
And WHICH version of cakewalk are you using and have you watched the tutorial videos yet?
No, I have not imported Ketron definitions. My reading suggested that Ketron’s audio could be heard without them and my attempt to import them has failed: From Cakewalk’s Knowledge Base, I opened Download User Created Instrument Definitions. That list does not include Ketron. From somewhere I found a zip folder claiming to contain them but Cakewalk’s Import Definitions tool did not recognize those files. So my boat is sinking and there’s a hole in my bail bucket. When/if I find those and get them imported, I'd be glad to talk.
Staff online
j levasseur
