Numa x piano: no sustenuto on e-piano sounds?
The Netherlands
I use the Studiologic SLP pedal (3 piece piano pedal) with the Numa X piano. The middle pedal is sostenuto, and works OK for acoustic pianosounds, but not for e-pianos. Also with single pedals it seems not possible to have sostenuto on the e-pianos. Does any body know something about this??
The Netherlands
If by e-piano you are talking about rhodes and wurlitzer emulations it is because they didn't have sustenuto. Only acoustic pianos have the feature.
That's what I thought too. I can imagine that some presets are build up like that. But I can't imagine that they deactivate a normal midi-controller-which works an all sounds- just because of such a silly reason.
The extra pedals may be assignable to wah or mod or some other FX. Check your settings for the individual voices.
golek
