Hey Col,
Thanks for explaining analogue for me. And thanks for all the other advice.
Firstly, The Audacity is working fine and the PC mike is recording ok. I have recorded a tune via mike and it works fine. But this does not interest me because it does not pick up some of the awesome DSP sounds produced by Yamaha. Also it will lose a lot of the bass. The clarity is missing big time.
I am only interested in direct line input "audio sound" not MIDI.
Before you splash out on the Behringer can you you describe precisely what you did, word for word?
Word for word would be encyclopaedic in my case. I also had some off line help (from Cowboy Paul for one). We tried all sorts of cables and connections and tweaked the settings across the menu bar top of Audacity's page. Splash out $75 is not such a big deal if it works and then I can run with it with simplicity.
Gary suggests I run with it too and Paul said also I definitely need some hardware.
Having tried leads through the Headphone jack (did not work) I also I bought other leads to fit the other jacks at the back of my KB (none of those worked either) However I got a message at the bottom of my PC screen that the computer was setting up my "Musical Keyboard" . . How did it know? Anyway no idea where that went! Audacity did not recognise it!
The U3A keyboard class had put me on a wait list until now. Now I have a spot but the tutor has taken a break for two weeks. I have met him and he has a PSR S 970 so will probably give me some good advice too. (when I finally get started). The IT courses are all full at the moment.
Anyway, thanks again.
Ray (patience is a virtue)
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
