Well, I’ve been thinking.
If I’m truthful to myself, I don’t believe I have what It takes to delve deep into the world of sound creation. What I meant by ‘fun’ initially is what it should exactly be : fun, nothing more. In other words, take a few moments of my day, sit down at my novice studio desk and basically muck around a bit with a music keyboard and my iMac and/or iPad.
I still have a pair of iLoud MicroMonitor speakers, and they will most certainly be perfect for this setup. So as much as I’d like to have it, I think the MODX8 will be a bit too much for me. Not that I’m dumb, but it’s unlikely that I will have the time needed to fully learn and appreciate the beast.
So, better not spend too much money. I was already looking at studio furniture, but the prices soon made me look elsewhere. And I got creative, and found what I needed at Ikea.
As for the board, I’ll probably go for the MX88. Good enough keybed (better than the one in the Kross 2 88) and really good sounds (to my untrained ear, anyway).
The free FM Essentials app really seems like a lot of fun (there’s that word again) and that’s more or less where my question about the Midi hub came from.
You connect an iOS device to the MX via USB to unlock all the sounds in the app, which can also be controlled with the knobs on the MX. But if my iPad is already connected to the USB to computer port, how will I connect my iMac ?
So, the problem is not a lack of USB ports on the iMac, but on the MX.
A MIDI hub might solve this, but how to set this up, I don’t know. Perhaps connect the MX, the iPad and the iMac to a USB hub, and MIDI will somehow do its magic and let me use everything at once, i.e. use Garageband or any other DAW on the Mac and control FM essentials via the MX on the iPad.
In my search for the answer, I found this :
For Yamaha synthesizer, workstation and stage piano owners seeking tips, sound libraries, support and a good place to hang out, yamahasynth.com is a user community that connects users with Yamaha unlike unofficial sites, yamahasynth.com has the Baddest Mister in town!
www.yamahasynth.com
Not exactly the same as my conundrum but interesting, nonetheless. Doesn't solve my problem, though.
I guess, if all that MIDI over USB magic shouldn’t work, the solution would be to simply use Garageband or Cubasis (instead of Cubase) on the iPad.
Moreover, and that’s just the way I am, in my mind, I’m already one step ahead…
What if in the future, I wanted to add a small MIDI keyboard to the mix ; a small 49 key model would suffice, I’m on a desk after all, just to use the MX’s sounds and give some extra room to play with (already found the perfect desktop stand for it). Something like the Alesis Q49, apparently quite good quality and it’s dirt cheap.
Suppose I get one of these, I’d connect it to the MIDI in of the MX and I’d be good to go ? There’s also the Q49 MKII (or the M-Audio Keystation 49 MkIII for that matter) but that’s USB only so that would complicate the USB connection thingy even more..
In essence, I don’t really know what would work best. I’d prefer to use the iMac, a lot more real estate than my iPad, but that brings the MIDI over USB problems with it. And I wouldn’t like to lose the Audio over USB capability of the MX, so I don’t know in what way using a USB/MIDI hub would affect this (if using any kind of hub would work at all).
If it should prove too complicated, I’ll just settle for my iPad, 12,9 inch isn’t too bad really and I can use it more or less as a computer with my Bluetooth keyboard and mouse (tried that a couple of times, works surprisingly well).
Right, I have ‘worked’ enough for the day, going to have a relaxing bath and maybe hit the Kawai ivories after dinner
