I have now received the Hercules stand. An impressive thing but I find the top tier can have a little side-to-side shimmy. Do you find this? I could maybe get used to it. I wonder if it's inevitable and if other double tier stands are like this too. The bottom tier is solid though.Hercules takes less than two minutes to put up hence why it is marketed as part of the Quicklock range.
Thanks Gary. I'm thinking just now that one could well have been the better one to go for. And I've found a place where I could get one from. A UK location.No shimmy at all on my Onstage stands. Bottom tier and top are securely locked into place when playing.
Gary![]()
Thanks Gary. I'm now thinking about sending the Hercules one back and ordering the Onstage. *Big sigh*Look at the differences in how the Onstage and the Hercules attach the second tier. The Onstage uses an extremely secure insert and locking T mechanism to attach the top tier while the Hercules seems to use a snap together design.
The Onstage also seems to be constructed of heavier tubing.
Gary![]()
