After what I experienced with the Krome,I cannot fathom the appeal of the Krome...at all.The Krome has been on the market since 2012 and Korg NEVER fixed the OS crashing issue that the subpar SD memory chip causes.Such memory cards(particularly the class 10 ones) are so incredibly inexpensive and yet,Korg is so maniacally greedy,they always use the cheapest garbage offered by the very lowest bidder,to construct their sh*t-boxes.Apart from the drum and piano programs,the Krome's soundset is terribly dated,tinny and thin.The Krome has no customer support,no expansion options and the only good & usable feature is the onboard song sequencer(but then,with the Krome being an utter failure as a synth(with Casio-like electronic sounds)...what's the point of utilizing the sequencer?Though the Kronos is still the leading hardware workstation...well...the OS(while functional & reliable)...is still slow,with no flash memory whatsoever,which is why I passed on ever buying one.Anyway....though I am puzzled as to why you like your Krome,I am glad it works for you and yes...I think I will have many years of enjoyment with my MODX7,thanks.![]()
I hope you and your MODX7 are very happy together.
If you think Korg support is bad I sincerely hope that you do not have to contact Yamaha, keeping my fingers crossed that you do not.
