- Joined
- Jun 25, 2010
- Messages
- 1,759
- Reaction score
- 642
If switching sounds seamlessly is important (which is what it sounds like from your other post about using a DAW), and you don't want to stretch the budget to the DS, then the MX at least gives you some of that capability, more than the Kross does. Another possibility in a lower price range could be the Casio XW-P1. It has pretty good seamless sound transition capability (also called "patch remain" and described at https://www.casiomusicforums.com/index.php?/topic/12589-patch-remain/ ) and has nice synth, organ, split/layer, and MIDI functionality. The downside is that its acoustic instrument sounds are probably weakest of the bunch. There's also the new Casio CT-X series which is less flexible, but has a newer sound set that probably sounds better. (I haven't played a CT-X myself.) It probably has the seamless transitions as well, since Casios usually do.MX61 or Kross 2? Juno DS costs more here in India. Kross 2 is Rs.47,000, MX61 is Rs. 50,000 and Juno DS is around Rs. 62,000.
