Adaptor specs
Hi, just seeking help with purchasing the correct adaptor for my Miles 668 keyboard.
I need an Australian adaptor and all I know is that it's 9v 800ma but I don't know the diameter of the DC end...I know that a 2.5mm female end is too big.
If anyone has a Miles 668 could you please advise? Thanks guys appreciate any help I can get.
I can't give you any specifics other than to search on Ebay for a compatible adaptor.
However I will give you a warning. Aside from the Voltage and Amperage ratings, you must also determine if the supply is a regulated supply or not.
Attaching a non regulated supply to a board that requires a regulated supply would be disastrous and could fry the whole thing.
Your best bet is to contact the manufacturer or an authorized Australian dealer and put the question to them.
They'd probably have a compatible adaptor in stock for a reasonable price.
Otherwise if you just randomly plug in any generic wall wart you are playing Russian Roulette.
