I am a keys player using a) ROLAND RD800 as main lower tier board with b) YAMAHA TYROS 2 on upper tier.
Usually take left and right output leads from each instrument into separate channels on a reasonably good mixer.
Mixer is then conected either to main out LEFT & RIGHT i.e. 2 x channels on main PA desk OR into my 2 x
YAMAHA ES-531 ES Powered speakers @ 250 watts RMS per cabinet. If not using these , I am able to use
a standard 2 x channel power amp (500 watts per side and 2 x full range 1000w speaker cabinets = in effect a small self-contained PA system just for the keyboards.
I am looking to move to powered speakers for weight/power and quality reasons as my back is knackered !!
PLEASE CAN SOMEONE URGENTLY RECOMMEND WHICH ONES I SHOULD BE LOOKING at ?
