Blackpool Sounds - Tyros 5
Long, long ago, I had a Tyros 5. I somehow succeded in loading the TTT Blackpool Wurlitzer sounds into it. Trouble is, I can't remember how I did it, Does ayone out there know how it's done? I'm planning to get my hands on the Tyros 5 once again and would like to repeat the trick.
The only way I know of is to use the Yamaha Expansion Manager (YEM) to create a custom voice. Although I'm not familiar with the program, I believe you can import soundfonts and WAV files into it for creating a custom voice. I don't think there's any other way to load expansion voices into the Tyros5.
sfz5
