Can we import multisamples in Roland BK9?
I'm buying a used Roland BK9. I knew that BK9 can import sample loops thru " Audio key"
function but wondering if it can also import multisamples or not?
Texas USA
I'm pretty sure that audiokeys is the only way to use samples in the BK-9. The newer, but slightly down-market Roland E-A7 has a dedicated sampling function. It doesn't have a ton of memory but I think it's the only arranger workstation designed for what you're trying to do.
Texas USA
I meant to say that the E-A7 is the only ROLAND arranger workstation that can import user samples. I knew that the better Korgs could for a while now. Re: Yamaha, can they import samples besides the prepackaged expansions that are offered by Yamaha?
