Casio CDP 130 - Power Issue
Hi,
I got this Casio CDP-130 for repair.
Please watch this video and see the problem.
Any idea how to fix it?
Does this occur only with the adapter plugged in or also with batteries installed?
I only have a 9V battery, with it installed the power LED lights only when I'm holding down the power button but no sound comes with a 9V supply.
First of all, Casios use C or D cells. Try it with proper Batteries and get back to us.
Thanks Gary , unfortunately I don't have C / D cells.
I've been told by the lady who owns this keyboard that she made a mistake and fed the keyboard with the wrong voltage and since then she can't turn it on.
Do you think that replacing the LA5756 might solve this issue?
First off I don't have access to a schematic.
Secondly, if she overloaded/reversed the power circuit chances are that nothing is salvageable on the board except for the mechanical components.
Could be blown voltage regulators, could be blown caps, could be some sort of hidden fusible link or the CPU itself could have been fried.
Authorized service center would just swop out the main board and be done with it. IF they still had the part.
Honestly this one is not worth the money to fix.
CDP-130 is at least ten years old and one of the lowest end pianos that Casio produced. It sold for about $500 new.
On the used market a working model is worth maybe $150 to $250 depending on condition.
Blown to hell it's literally worthless.
Seriously it's not even worth that much for spare parts.
Tell the poor woman it's time to buy a new keyboard.
I just watched the video again. It does still produce a note if you hold the button so the problem is in the power circuit.
Do you have a schematic or a service manual for this thing?
Google to see if you can find one.
It's something affecting the latch circuit of the soft on power button. probably a blown semiconductor.
You'll need a schematic to track it down.
I cannot access the schematic on your google drive link. You have to set that file to public.
I found the problem!
IC1 (headphones amp) was faulty.
I felt it was getting too hot so I removed it and now the piano works!
I'll ask the owner if she want me to install a new headphones amp or I can leave it like this.
Hi I just got a keyboard with the exact same issue! Only works holding power button! So did u fix it removing the IC1 headphone amp? How can I do that? Where is located? Thank u so much
Best
RB
eli
Buen dia, no soluciona el problema cambiando el LA5756, yo tengo este mismo problema, cambie el regulador y nada, sigue igual
golek
