Casio CTK-240 not turning on
Pressed tone and power on my CTK-240 BUT NOT Turning on put new batteries in still dont work nothing happens when i turn it on
Welcome.
Sorry to hear of your problem.
Do you only use the keyboard via battery power?
If you do are the battery terminals clean?
Can you see any broken wires in the battery compartment?
Is there a smell of burnt plastic coming from inside the keyboard?
Cam you connect a power supply and see if that works?
Do I take it that your pressing Tone and Power is supposed to do a hard reset?
Given the cost of the keyboard it will certainly not be economic to have a Tech look at it.
Maybe its time to look for a new Casio CTX
